jaylee
Post
by jaylee » Mon Oct 08, 2012 7:08 pm
In fairness you may only need to jiggle out part 61-896
The fan housing (far right under your hanging controller.) from memory is the two screws on the top (you can see em on that tab bit.) & a bolt to the side of the floor
to remove separately by kind of wiggling it from the side duct to the evaporator & heater housing?? That will just leave the main air con & heater unit with the flaps in to remove.... Bracket from fan unit to the floor pictured here..!
I don't envy you....
Colin H F
Post
by Colin H F » Mon Oct 08, 2012 7:19 pm
Hi Simon Jay, cheers guys Jay the upright section should be easy there is a lot of play in it and it actually lifts up and clears the housing, so Simon I don't think I will have to take any more trim off,
jaylee
Post
by jaylee » Mon Oct 08, 2012 7:21 pm
I think there is a third floor bracket you have not exposed under the after-market flooring far right..?
Post
by Simon Jones » Mon Oct 08, 2012 7:22 pm
You'll probably be ok. I didn't have the luxury of a sodding great hole cut out of my panel through which to remove it
. Watch out for coolant and A/C oil when you lift it up as it will dribble out the holes below.
jaylee
Post
by jaylee » Mon Oct 08, 2012 7:31 pm
I'm going to be a bit cocky here,
& air on just removing the top part of the heater housing by removing the multiple fiddly clips then replacing the evaporator in situ....? That way you still have a drivable vehicle without the arse end of the coolant system removed too...!??
Colin H F
Post
by Colin H F » Mon Oct 08, 2012 7:41 pm
jaylee
Post
by jaylee » Mon Oct 08, 2012 7:52 pm
Yep these 61-A09's are a pain especially on the outer skin side....
Take it slow & steady either way, the heater housing isn't that "robust".....
Colin H F
Post
by Colin H F » Mon Oct 08, 2012 8:09 pm
Are they plastic or metal I am thinking of making a tool to un clip them and hold them so the don't drop down
jaylee
Post
by jaylee » Mon Oct 08, 2012 8:15 pm
METAL... It maybe a little easier to retrieve them if they do drop when the top half of the heater housing is removed..?? I don't know.. A magnet ended rod will pull to anything down there...!
Colin H F
Post
by Colin H F » Mon Oct 08, 2012 8:21 pm
Yep exactly what I had in mind
jaylee
Post
by jaylee » Mon Oct 08, 2012 8:30 pm
I think from memory.... I kind of scooted anything i dropped down there to the right hand side with a stick & because the fan housing alone was removed, i could get my hand in the sill cavity space & retrieve....?
Colin H F
Post
by Colin H F » Mon Oct 08, 2012 8:44 pm
jaylee
Post
by jaylee » Mon Oct 08, 2012 9:05 pm
Post
by Northern Bongolow » Mon Oct 08, 2012 9:36 pm
same seller. married i believe. very good family run business, and good bongo parts.
Colin H F
Post
by Colin H F » Mon Oct 08, 2012 10:37 pm
but why two different prices & P&P for the same item nearly £18 difference
