After 2 years of faithful service my Bongo has started oozing oil out of the engine. There is an area of fresh black oil on the side of the block on the drivers side near the big pipe on the front.
No sign of any contamination of the engine oil or coolant. No obvious problems with the engine running.
Here are some not very good photos. You can just make out the oil in the back of them. The pipe on the right of the photos is the big pipe to the radiator. The bolt on the second photo is the highest point of the oil stain and might be the source.
Any suggestions???
