Stuck Side Door
ScubaBongo
Stuck Side Door
Post by ScubaBongo » Sun Mar 15, 2009 6:44 pm
Hey Guys,
My side door is stuck closed after a fully flat battery, just like in this post: http://www.igmaynard.co.uk/bongo/forum/ ... =3&t=28488
Does anyone have any advice on how to rectify it?
I found an entry on "FixYa" relating to the Mazda MPV side door. I'm wondering if there's any crossover..
http://www.fixya.com/cars/t1262577-remo ... door_stuck
Thanks as always
SB
westonwarrior
Re: Stuck Side Door
Post by westonwarrior » Sun Mar 15, 2009 7:30 pm
You can give it a thechnical thump along the door and see if it jolts the mechanism to start or
disconnect the battery and reconnect, it that can help or
take the inner panel off the door and try to click the micro switchwhich will reset it or pull the cable in side the door to release the catch which again may breath life back into the mechanism
Re: Stuck Side Door
Post by Doone » Sun Mar 15, 2009 7:35 pm
That's what we had to do, it's a pain. :)
ScubaBongo
Re: Stuck Side Door
Post by ScubaBongo » Sun Mar 15, 2009 7:48 pm
Thanks guys.
Already tried dis/reconnecting battery, no luck.
I'll try the "technical thump" rountine next...
taking the door panel off does indeed seem a pain. Can this problem rear it's ugly head every time you disconnect the battery then?
helen&tony
Re: Stuck Side Door
Post by helen&tony » Sun Mar 15, 2009 7:53 pm
No...It doesn't happen every time you disconnect. I have removed the battery on several occasions. The Bongo Thump often works
ScubaBongo
Re: Stuck Side Door
Post by ScubaBongo » Sun Mar 15, 2009 9:01 pm
Tried a bit of Bongo Thumping, but no luck.
Exactly were should I hit it? (Neighbours must think I've gone mad, randomly punching my Bongo!)
I have a horrible feeling I'm going to be taking a door apart soon :(
al & chris
Re: Stuck Side Door
Post by al & chris » Sun Mar 15, 2009 9:18 pm
Thump it towards the bottom rear quarter af the door looking from inside if it works you will hear the lock return when you hit it.
Al & Chris
ScubaBongo
Re: Stuck Side Door
Post by ScubaBongo » Fri Mar 20, 2009 11:38 pm
not entirely sure what worked, but it was something like waggling one of the metal rods inside the door mech, while operating the handle, a bit of punching, and some swearing.
It's sorted. :D :D
Re: Stuck Side Door
Post by missfixit70 » Fri Mar 20, 2009 11:40 pm
I find a bit of temporary Tourettes usually does the trick :lol:
mikexgough
Re: Stuck Side Door
Post by mikexgough » Wed Dec 22, 2010 9:58 pm
Found this for future reference
Photos and Jap/english translation ish....... :lol: "near the liver" :lol:
jaylee
Re: Stuck Side Door
Post by jaylee » Wed Dec 22, 2010 10:25 pm
missfixit70 wrote:I find a bit of temporary Tourettes usually does the trick :lol:
But only if you feel "clogged at the brink of Hun's last Kashatsu." :wink:
