HELP! Sliding side door will not unlock and open
JamesC
My battery went flat and the automatic central locking stopped working. Whilst the battery was still flat, I opened and closed the doors with my key, instead of the remote. I heard the side door lock bolts lock into place, very slowely, using the remaining juice in the battery. My van was left over night and started again the next day using jump heads.
The problem is that everything now works again, including the central locking, apart from the fact that the sliding side door remains locked shut. Does anyone know what I can do to unlock the door, apart from force it? . . . .even that will be difficult, given the size of the door bolts.
Re: HELP! Sliding side door will not unlock and open
There is a top tip to sort this, the mechanism has jammed.
Do not take the door card off etc and poke about until you try this:
Bang the inner side of the door hard with the flat of your hand, do it about a third of the way up. It has to be quite hard. Don't worry as although it might hurt your hand it won't damage the door card.
Good luck
Good luck
JamesC
Thanks for the quick reply . .I'll give it a go.
JamesC wrote:Thanks for the quick reply . .I'll give it a go.
Hope it works, got the tip via Doone - see here:
http://www.igmaynard.co.uk/bongo/forum/ ... =3&t=37095
Vicky007
I had the same problem when my Autonator was replaced, was told by the garage it was due to the door linkage bit wearing away they filed it down and now works perfectly but may not last forever so may need to replace the linkage at sometime, hope this may be of help to you, Happy Bongoin!
- mister munkey
Another lifesaver
HERE
HERE
JamesC
Brilliant . . . it worked . .the fonze school of solutions!
JamesC wrote:Brilliant . . . it worked . .the fonze school of solutions!
aaaaaaaaaaaaaaaa....
Was that the sound he made?
Well done Mr C
- mister munkey
Another quick cost free fix assisted by the Crew!!
Well done all.
Well done all.
TeeJay
Wicked guys, it just worked for me too
trouble is I'd forgotten about my bad wrist and it's killing me now DOH !
Thanks, I'm now an officianado of the Foz school of fixing things
