I have learned that i can expect egr gunk on my engine
but would you say that its normal for a diesel bongo engine to have oil all over it? (60-70%)
i have been told that these engines are very oily engines
my gearbox has oil all over it , sump is covered in oil, oil is coming out rocker cover
i have an oil covering on the bit of the engine that has the two belts on it at the front of the engine, oil is baiscally evey where below the rocker cover(but not caused by the rocker cover leak as this is not to bad).
how many of you have a engine that has no signs of oil except the EGR gunk?
Thanks.
