help with heaters
You've Been Bongod
help with heaters
Post by You've Been Bongod » Thu Apr 29, 2010 7:35 pm
can some one please help me
manual heaters (front)
changed motor as couldnt spin it
changed resister also
still no heaters
there is power there because when switch front to number 1 and press rear the rear work
any idea's welcome
Re: help with heaters
Post by missfixit70 » Thu Apr 29, 2010 7:37 pm
Is the power getting to the fronts though? could it be the controller? iffy connections or loom to the front?
You've Been Bongod
Post by You've Been Bongod » Thu Apr 29, 2010 7:41 pm
i will check that tommorrow thanks
Post by missfixit70 » Thu Apr 29, 2010 7:44 pm
Check the fuses under the bonnet, different fuse for front & rear heater, diagram in members area :wink:
You've Been Bongod
Post by You've Been Bongod » Thu Apr 29, 2010 7:46 pm
i thoght front and rear fuses were the same as both 30 amp #-o
Post by missfixit70 » Thu Apr 29, 2010 7:50 pm
You've Been Bongod wrote:i thoght front and rear fuses were the same as both 30 amp #-o
If they're "both 30a" how can they be the same as if there's a both that implies 2? :wink: Don't quite understand the logic of that statement :lol:
You've Been Bongod
Post by You've Been Bongod » Thu Apr 29, 2010 7:57 pm
i meant to say that the front and the rear fuse in my bongo is 30a thats why i thought they were the same
Post by g8dhe » Thu Apr 29, 2010 11:00 pm
There are two seperate fuses one 30 Amp for the Front Heater and one 30 Amp for the rear heater, hover your mouse over the Heater and R. Heater fuses and it will show you the positions.
Fornt Heater
Rear Heater
You've Been Bongod
Post by You've Been Bongod » Fri Apr 30, 2010 10:58 pm
i have got a feed to the heater control as with engine running i switch heater control on and get a change in engine revs
switch back off and revs go back to normal
goin to try a new resister tommorrow
Post by missfixit70 » Fri Apr 30, 2010 11:05 pm
You sure the fan works? Try 12v across it direct & see if it spins up.
You've Been Bongod
Post by You've Been Bongod » Fri Apr 30, 2010 11:09 pm
the breakers i bought it from said it was working when they took it out of the bongo
Post by missfixit70 » Fri Apr 30, 2010 11:10 pm
Of course they did :wink: test it anyway
dandemann8
Post by dandemann8 » Fri Apr 30, 2010 11:14 pm
Carl, just have a barbie and have done with it :lol: :lol: :lol:
Bongo no more........... ;-(
