Non coolant leak
eoptio
Non coolant leak
Post by eoptio » Thu Jun 10, 2010 9:44 pm
Hi all
just noticed some watery liquid under the van, not coolant, seems to be coming from near the intercooler, any ideas?
thanks
K
Re: Non coolant leak
Post by missfixit70 » Thu Jun 10, 2010 9:45 pm
Had your ac on? condensate drain?
eoptio
Post by eoptio » Thu Jun 10, 2010 9:50 pm
thanks for quick reply! Yes had the aircon on few days ago (never used it before), forgive my ignorance, but what is the condensate drain and is it normal for this to happen when using the aircon?
thanks
K
jaylee
Post by jaylee » Thu Jun 10, 2010 9:52 pm
Drain tube that removes the rain water from the gully under the windscreen??
..I know it's a bit further forward? But Water always seem to give the appearance of coming from somewhere else... :D
Post by missfixit70 » Thu Jun 10, 2010 9:53 pm
yup, totally normal, water condenses on the cold evap matrix as the air flows through & drains out of the bottom scaring you witless that you've just sprung a leak :wink:
eoptio
Post by eoptio » Thu Jun 10, 2010 9:58 pm
thanks all
yes it did worry me a bit..
K
jaylee
Post by jaylee » Thu Jun 10, 2010 10:01 pm
missfixit70 wrote:yup, totally normal, water condenses on the cold evap matrix as the air flows through & drains out of the bottom scaring you witless that you've just sprung a leak :wink:
:lol: Same with the gully pipe! melted ice on the van leaving a puddle in the front center of the foot print!! :shock: #-o :idea: :lol:
Post by mikeonb4c » Thu Jun 10, 2010 10:16 pm
Same with my pee-tube. Scared myself witless one morning till I realised coolant was a green colour :lol: :lol: :lol: :lol: :lol:
Post by Bob » Thu Jun 10, 2010 10:38 pm
One doesn't like to ask the colour of draining liquid. :shock:
bobngo
Post by bobngo » Fri Jun 11, 2010 8:41 am
for those that don,t know ,this really helps on those cold frosty/windscreen fogged up mornings, start engine, put heat to max on windscreen , turn on air conditioning , a/c is now hot DRY air , and so demists screen much quicker.
so a/c is not only for those lovely hot days but cold damp/wet as well
sorry if i seemed to hijack this thread , but it just seemed to fit in with the topic !!!!!
jaylee
Post by jaylee » Fri Jun 11, 2010 10:30 pm
bobngo wrote:for those that don,t know ,this really helps on those cold frosty/windscreen fogged up mornings, start engine, put heat to max on windscreen , turn on air conditioning , a/c is now hot DRY air , and so demists screen much quicker.
Fair play! :D Yer meant to put it on at least once a month fer a while to keep it lubed...??
I think!?? :wink:
carlioll
Post by carlioll » Fri Jun 11, 2010 11:14 pm
Not sure that condensate drain is the answer. Eoptio said that he had the aircon on a "few days ago".
eoptio
Post by eoptio » Sat Jun 12, 2010 12:26 am
thanks for answers all, no more liquid under the van today, yes it was a few days ago I had the aircon on, not driven since, rained quite a lot here recently so perhaps combination of air con drain and the drain tube. No idea what else it could be?
K
