Leisure Battery compatability
Blueskai
Post by Blueskai » Fri Jul 02, 2010 7:09 pm
Apologies if this has been covered before.
I am planning to fit a LB. My main battery is 75ah - does the LB need to be the same or can I fit a 110ah? I hope to fit a split charger too.
LB or not LB, that is the question.
Re: Leisure Battery compatability
Post by missfixit70 » Fri Jul 02, 2010 7:16 pm
Bigger the better :D 110ah will be fine, may be a tight squeeze but it should fit, if you've got to get aLB tray & split charge, go for the willinton kit.
Blueskai
Post by Blueskai » Fri Jul 02, 2010 7:25 pm
Can you post me a link for the Willinton tray and charge kit, please.
Post by missfixit70 » Fri Jul 02, 2010 7:29 pm
Nothing listed ATM, but contact him through ebay & see if he's got any ready to go, tell him we sent you :wink: http://myworld.ebay.co.uk/willinton/
Blueskai
Post by Blueskai » Fri Jul 02, 2010 7:30 pm
Contact who?
Post by missfixit70 » Fri Jul 02, 2010 7:40 pm
Post above updated :oops: #-o
Blueskai
Post by Blueskai » Fri Jul 02, 2010 8:12 pm
Thanks Kirsty. V. Helpful, as always. x
scanner
Post by scanner » Fri Jul 02, 2010 8:23 pm
You will have to be very careful with a 110amp as some are too high and the bonnet may short the terminals out when you close it.
Blueskai
Post by Blueskai » Fri Jul 02, 2010 9:18 pm
Good point. Maybe 100 ish would be safer
Post by missfixit70 » Fri Jul 02, 2010 9:42 pm
With willinton's battery tray, this should not be a problem, it's built around a 110ah Numax (which I've got) & I've fitted a couple of other different makes without issue.
scanner
Post by scanner » Fri Jul 02, 2010 10:04 pm
scanner wrote:You will have to be very careful with a 110amp as some are too high and the bonnet may short the terminals out when you close it.
SOME m/home 110amp leisure batteries are huge compared to a Numax one and will not fit.
I know - I have one in the m/home that will not even fit in the tray, let alone under the bonnet of a Bongo.
All I'm saying is don't just go out and buy any old 110amp and expect it to fit.
Post by mikeonb4c » Sat Jul 03, 2010 10:40 am
Yup. What I do (did) was look up the Numax 100 dimensions online and make sure alternatives don't exceed those dimensions (also how the terminals are arranged - from memory so correct me someone if I'm wrong, you want it so the negative terminal is on the right and at the back). In the end I got a Numax 110Ah 2nd hand off ebay anyway.
However, when I replace it I think I may get an Elecsol 100Ah as it seems to be better suited to higher current drains, should I need that. Have a search for Elecsol on here and you'll see what people have said (Ron Miel especially).
dave_aber
Post by dave_aber » Sat Jul 03, 2010 11:09 am
With the Willinton kit, the neg lead is at the right, but it can reach the front or back of the battery, as can the pos lead, so either way round will fit. I suppose Neg rear right, pos rear left would give you a tad more headroom above the battery terminals due to the slope of the bonnet. I have mine at the front on a Numax CXV30HMF 113Ah.
Image...Image
