Post
by mikexgough » Mon Sep 27, 2010 12:25 pm
initial diagnosis with your symptoms being lumpy on cold starts....... sounds to me like Glow plug or plugs not working..... now if your a Veg user....could be the percentage Diesel/Veg needs adjusting....
If you like me and suspect say a glow plug....change the lot....that's what I do with anything on the Bongo....at least it is preventative maintenance not reactive, which is what the Japs do....... For example if a bush is worn on the roll bar.....change all the components....that kind of thing, so for me if a glow plug fails....I change 'em all..... a) they are all the same age & b) you know when they were changed and what parts you used.....
