when i do an emergency stop or go over a big bump the oil light comes on and a strange soft ticking noise happens. in variably when i switch the engine off and back on the oil light goes off.
i had the oil switch replaced but problem still there
after bumps /hard braking oil light and slight ticking noise
kickinthebongos
- dandywarhol
Re: after bumps /hard braking oil light and slight ticking noise
Check the oil level?
kickinthebongos
Just a thought... Any other inconsistencies with the dial pod read out when this happens..?
Tripewriter
Put another litre of oil in.
- haydn callow
Just a thought....you are checking the engine oil and not the Auto box level.....????
- gmaczbongo
Are you looking at the right warning light.
Not sure about the bongo, heavy braking and lowish fluid will have the brake warning light flashing.
