Water Leak (dripping) please help
Eyup everyone
~just noticed water dripping underneath~i can see where it's coming from but don't think it is coolant related (hopefully)~~from the pic it's that plastic hole at side of cable~could someone advise please.
Regards Ray & Christine
Re: Water Leak (dripping) please help
Aircon condensation nothing to worry about.
Julian
Julian
Thanks a lot Julian~~it seems to be quite a drip~but your put my mind at rest321Away wrote:Aircon condensation nothing to worry about.
Julian
bigdaddycain wrote:RESULT!![]()
Yeah Ste~~with my lack of knowledge with Bongo's & water the slightest sign of water makes me panic
- Bulwell Bongoleers
- Tribal Elder
Yes all sorted~~~so it's full steam ahead tomorrow~(if that's the right expression)Bulwell Bongoleers wrote:Looks like you got your answer Ray.![]()
- You've Been Bongod
thats why you never wash the bongo then rayTriple/R wrote:bigdaddycain wrote:RESULT!![]()
- mikexgough
Your paranoid Ray....... maybe you should drive a Mondeo.......
The other day I noticed water cascading down immediately underneath the the engine tray.
As I had recently dealt with a coolant leak, I momentarily went into a blind panic. Although it was raining there seemed no reason why water should run off the bodywork there.
Well, I soon realised that rainwater should run out there and when it does it proves that the drain below the windscreen is working properly.
If in doubt put a bowl underneath. If it fills with clear drinkable water it is rain or condensation.
Frank
Frank
They flew, I took up naturism
Blimey Ray - I was holding me breath for you whilst I read this post, phew. Going to exhale now
Yeah thanks Carl~~~but after a great effort i've managed to clean it
Yeah Mike you know me (paranoid) & the Mondeo comment is hitting below the belt
Eyup Graham
~yes i did'nt want to go through what you did recently but happy yours is behaving now
See you all later.
Eyup Graham
See you all later.
aitch
- Location: in a place far, far away, well Somerset for now!!!
Glad you found out what it was Ray - you can breathe easy again now.
Thanks Aitchaitch wrote:Glad you found out what it was Ray - you can breathe easy again now.
That's what foxed me at first,cus the drip was very close to the drain pipe from the windscreen & it was'nt even raining or wet.Diplomat wrote:The other day I noticed water cascading down immediately underneath the the engine tray.
Frank
