Just wondering if any one knows anything about buying new cylinder heads, ours has got a crack in it and needs replacing.
there are loads on ebay but they range from £200 -£500 in price and all claim to be a 'genuine replacement part'
Any advice- which do I buy? Will it need skimming when it arrives? Why is there such a price difference?
Is it simply more money buys better quality? they all look pretty similar too me
advice buying new cylinder head
fredasurf
- mister munkey
Re: advice buying new cylinder head
This is one of those things where the You Get What You Pay For rule applies.
For £200 you get a basic head, probably a Chinese copy & likely to be for a Ford Ranger.
In the £500 bracket you're paying for a fully built unit from a reputable source complete with camshaft, valves etc, ready to bolt on. (Genuine Mazda heads are priced over £1200!)
You'll also need a gasket & a set of head bolts too.
The cheap ones will invariably cost a lot more in the long run.
The Club Shop does decent ones as does Bongo Bits.
wishmaster
- Tribal Elder
Thats good advice from MM, in these cases go for the best you canmister munkey wrote:This is one of those things where the You Get What You Pay For rule applies.
- maxheadroom
got mine from the club shop comes with everthing you need, including member discount
Cheap head gasket sets are a major pain, its worth paying a bit more and knowing that its going to work rather than spend hours fitting only to find its all been a waste of time and you have to replace it anyway!
- You've Been Bongod
pm sent
