Fitted new radio/cd player
tharg
Hello kind people, I have read the factsheets about fitting a new radio in place of the old japanese original and felt confident that all would go well, I bought the PC2-10-4 adaptor as suggested and got a nice new Sony radio/cd player. I removed the old player as per instructions on factsheet, no problem, I then connected up all the new connectors from the new player through the adaptor into the old bongo connectors, everything fitted as described, but then, I'm left with all these spare wires which I don't know what to do with. Firstly coming from a black box connected to the aerial cable I have a thin black wire, what's it for? Then on the PC2-10-4 I have a black wire with a loop connector? Coming from the battery area I have a thicker black/red wire which Stuart Chambers refers to in the factsheet as the earth wire, where do I connect this to? And finally on the new player itself I have a blue/white wire with a label on it which reads, AMP REM MAX 0.3A, and has a female connector on the end. Any help would be greatly apprieciated.
Re: Fitted new radio/cd player
The blue white wire with REM on it sounds like the remore wire. That is only required if you're connecting the new radio to an amplifier. Have you switched the unit on yet?
I forgot to mention,
Just tape the remote wire up if you aren't connecting the stereo to an amp.
tharg
Thanx, at least thats one wire out of the way, and no I haven't put it on yet I didn't want to until I had dealt with all the wires first!
Sorry i can't advice you further Tharg... Mine already had an ISO plug fitted so i just clicked my stereo in. I'm sure somebody will advise you further when they spot this...
tharg
thanx again, any reply is much welcome
It sounds like the thin wire comming from the ariel is possibly to do with a band expander that may have been fitted to allow the original radio to pick up more uk chanels - this may have another adaptor that the original ariel plug is connected to.
The PC2 10 -4 that you have bought has an earth on it. You could connect this to the vehicle body somewhere under the dash, but there is usually a black (could be black /red ?) wire with a black push on female spade connector that goes on the original stereo. I just put a male spade on the end of the PC2 10-4 earth, and connect to this.
Hope this helps a bit....but sounds confusing
tharg
Madmile this sounds good, the black/red thicker cable coming from the battery area of the Bongo has a spade on it which went into the back of the old radio, I will do what you suggest and connect the spare cable from the PS2-10-4 to this cable and see how it goes. Let you know how I get on.
tharg
Just to let you kind people know that i'm up and running, a big thanx to bigdaddycain and madmile for there advice , it worked. Also if anyone else is going to be changing there original radios and need a PC2-10-4 adaptor don't pay £10 for one follow the link bellow, I got mine from Liquidice for £1.48 and free P&P
PS I don't know how to make the link work so you'll just have to copy and paste, Cheers
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... 0590087299
tharg
OOPS the link does work, all the best!!!!!!!!!!!!!!!!
Whatever doesn't destroy you will make you stronger
Great result Tharg!
And thanks for the tip/link!
Now go bump some tunes!
wishmaster
- Tribal Elder
Just where i got mine from, not the £16.99 like in Halfruadstharg wrote:Just to let you kind people know that i'm up and running, a big thanx to bigdaddycain and madmile for there advice , it worked. Also if anyone else is going to be changing there original radios and need a PC2-10-4 adaptor don't pay £10 for one follow the link bellow, I got mine from Liquidice for £1.48 and free P&P
Enjoy
