Finding a coolant leak
Paulinwales
Post by Paulinwales » Wed Feb 23, 2011 8:35 pm
I think i read somewhere about using UV dye to identify coolant leeks
anyone got any info i.e. how to get some, how much it costs, or are there better ways to identify the sourve of the leak?
I am leaking somewhere and going to change hoses but not sure where the leak is
rgds p
Re: Finding a coolant leak
Post by Northern Bongolow » Wed Feb 23, 2011 9:26 pm
any good garage can do a static pressure test.or you can make your own.
do a search for pressure test kit on the forum.
Post by mikeonb4c » Wed Feb 23, 2011 9:44 pm
Paulinwales wrote:I think i read somewhere about using UV dye to identify coolant leeks
rgds p
Haydn Callow was very generously offering to post small bottles of u/v dye to enquirers, for a modest cost, some while back. Might be worth PMing him. Then of course you need to buy the u/v torch/lamp with which to spot the source of the leak 8)
TonyBee
Post by TonyBee » Wed Feb 23, 2011 10:10 pm
I recommend this one:
http://www.amazon.co.uk/Torch-Flashligh ... 338&sr=8-4
Worked a treat when I was searching for a leak on my boy's car.
And here for the dye:
http://www.carairconditioningsupplies.c ... ductid=836
Tony
mikexgough
Post by mikexgough » Wed Feb 23, 2011 10:16 pm
If you have Red coolant in your system then that contains a dye....when it leeches out it shows a pink trace.. :wink: along with the bonus that it is as chemically close to factory spec coolant as possible (other than colour - but that's another story :roll: )
Paulinwales
Post by Paulinwales » Wed Feb 23, 2011 10:41 pm
cheers guys fantastic info- impressed! :D
