Hi All, I have previously mentioned that I ended up using a small drill to drill a hole in my steering rack top seal, then used a woodscrew and pliers to remove it.
The only downside to this was the risk of the drill slipping and damaging something it shouldn't have.
A guy with a Land Rover has used a small sleeve slipped over the drill bit to prevent this happening, this should show the drill and the sleeve, which only allows the tip of the drill to protrude.
http://lifeattheendoftheroad.files.word ... =602&h=452
Power Steering Top Seal Removal Tip
Re: Power Steering Top Seal Removal Tip
