Help please
Colin S
Help please
Post by Colin S » Sun Jun 05, 2011 9:12 pm
Can someone please answer a simple question for me, I have a full camper side conversion which includes 110 amp leisure battery. Should this battery if correctly wired in charge up when the vehicle is in motion. My van has 3 batteries now, two in front and an inboard leisure battery. Do I actually need two batts in the front, sorry if this sounds dumb but Im not a techie person.My inboard battery always seems to be going flat even when Im on mains hookup and Im continually having to put the charger on to keep it charged up. I want to go without electric hookup this summer but if batt keeps going flat not much chance of that.
Colin
wonkanoby
Re: Help please
Post by wonkanoby » Sun Jun 05, 2011 9:27 pm
some bongos came with 2x starter batteries as part of a winter kit
as to charging yes usually but your inboard batteries not usual
Re: Help please
Post by g8dhe » Sun Jun 05, 2011 9:34 pm
It will vary from conversion to conversion as they are basically custom, not many fit a third battery internally however. Can you name who did the conversion and style, others may have the same type and can comment. The only other way to find out is ring the converter, or start investigation the wiring. Do you have a EHU fitted as well ?
Colin S
Re: Help please
Post by Colin S » Sun Jun 05, 2011 9:38 pm
Yes we have EHU...when I had a motorhome some years ago this did charge when driven......seems a bit excessive 3 batteries.
dandemann8
Re: Help please
Post by dandemann8 » Sun Jun 05, 2011 9:42 pm
Sounds like the winter kit to me :wink:
Bongo no more........... ;-(
