water!!
bongo-babe
water!!
we drove 150 miles and then we heard a horrid noise and clonking. we then discovered that there was no water left. we filled it up and heaed back. again this has happened since and also noticed this time that the temp gauge had risen. we then discovered that the water had disapeard again. i did leave the fan on hot all the way home whiched kept the temp guage at half way and the odd flicker below towards cooler. any ideas?
i have checked the pipe under the seat and the pipe is in the clip still and seems ok.
i have also checked the oil and its jet black.
im also a girl so should i take it to the bongo dealer or is there soething i can do??
- westonwarrior
Re: water!!
firstly dont drive it
if you got it from a dealer as I know you havent had it long and it is a diesel contact them.
Could be many thing but what it isnt is good
loud noise and clonking?
Are the belts intact? could be the water pump or belts, or much worse.
but do not drive it until its been bled peoperly and checked over by some one who knows what they are looking for
bongo-babe
Re: water!!
oh crikey! right i will get it seen on monday am. do you think i should drive it the three miles to the dealer??
thanks
thanks
- westonwarrior
Re: water!!
I would speak to them first, let them make that decision
bongo-babe
Re: water!!
Thanks for advice. i will let you know what they say.
- westonwarrior
Re: water!!
I am taking it it is still under warrenty
bongo-babe
Re: water!!
they only gave me 6 months but the garage man is young and im sure i can bat my eye lids. if not do you think that a normal car garage owner would be able to figure it out as i have a friend who owns his own garage. unsure whats best.
- mister munkey
Re: water!!
The waterworks on a Bongo aren't like a regular car. Once the top up water tank is empty air gets into the system. Topping it up is a fruitless venture.
If your temp guage has gone up & its not been previously been modified, its probably already too late.
I'm happy to be proved wrong but it sounds like head gasket at least, (£400+ for a fix)
bongo-babe
Re: water!!
yikes!!!
i hope your wrong but i have a horrid feeling your right!!
- mister munkey
Re: water!!
Get in touch with Allans in Plymouth http://www.allansvehicleservices.co.uk/
They will sort it swiftly & smoothly.
bongo-babe
Re: water!!
Yahoo!!! Bongo is fixed. There was a hole on the pipe under the passenger seat! So thankfully it was a small problem and not a massive expensive.
Re: water!!
bongo-babe wrote:we drove 150 miles and then we heard a horrid noise and clonking. we then discovered that there was no water left. we filled it up and heaed back. again this has happened since and also noticed this time that the temp gauge had risen. we then discovered that the water had disapeard again. i did leave the fan on hot all the way home whiched kept the temp guage at half way and the odd flicker below towards cooler. any ideas?
There are no garages in exeter that i would give my puppy to/recommend
D
Re: water!!
Still keep an eye on it for next while just to be safe
Julian
Julian
Re: water!!
dare i ask who you bought it from
D
bongo-babe
Re: water!!
Yep sure I got it from Topsham car sales. They do specialise on bongos and import them all the time. Anyway they collected it from home and are alo returning it too. Turns out it's the pipe under the passenger seat it gad perished and was leaking water like a fountain. Despite me checking that anyway it seems with a pressure test or something then it showed it was knackered. I did squidge it and it was a bit I'm crumbly and crackly when I squeezed it. Unsure of costs yet but got to be cheaper than that swear word (gasket)
