coolant alarm ( fitting)
rivermouse
Post by rivermouse » Wed Aug 10, 2011 7:21 pm
Can anyone tell me which battery terminal to disconnect when fitting a coolant alarm and what colour is it? Also where do I earth the red and black wire? Also how do I remove the spare wheel from under the van and any ideas about the rear wiper not working-I think that is it!
Many thanks,
Newby
westonwarrior
Re: coolant alarm ( fitting)
Post by westonwarrior » Wed Aug 10, 2011 9:55 pm
to fit the alarm its probably best to remove the negative terminal
earth to any chassis bolt especially if another earth is connected there
She spare is lowered via a elongated hole inside the rear door with the lowering tool and ratchet in the compartment in the side door step.
Post by missfixit70 » Wed Aug 10, 2011 9:59 pm
The rear wiper is probably the wiring between door & body - http://www.igmaynard.co.uk/bongo/forum/ ... rear+wiper
Post by missfixit70 » Wed Aug 10, 2011 10:05 pm
If you are not planning to already, ditch the space saver spare if you've got one under there & replace with a full size spare.
Post by Bob » Wed Aug 10, 2011 10:23 pm
The long bar is often clipped to the 'roof' of the compartment by the step in the side door, and can be tricky to find if you don't know that. :wink:
rivermouse
Post by rivermouse » Fri Aug 12, 2011 5:36 pm
Thanks very much for the advice am now off to tinker!
321Away
Post by 321Away » Fri Aug 12, 2011 8:08 pm
Auto electricians golden rule is 'negative terminal, disconnect first, reconnect last'
Julian
