Radio Bongo...
hooch
Radio Bongo...
Post by hooch » Fri Nov 16, 2012 3:47 pm
I've just replaced the strange array of electronic equiptment and Japanese audio bits that frequented my dash.
The new stereo works well with the exception of a radio signal.
The aerial antennae is plugged in but does not seem to be giving any kind of signal...
Does anyone have experience to share that might help resolve the issue?
Re: Radio Bongo...
Post by g8dhe » Fri Nov 16, 2012 4:13 pm
Check back along the aerial cable there is another plug and socket just under the the dashboard area where the cable rises up the side of the window screen;
See here http://lushprojects.com/bongopartsmk2/c ... mgno=.html
hooch
Re: Radio Bongo...
Post by hooch » Fri Nov 16, 2012 5:11 pm
Hi Geoff,
Checked this back - seems to be joined - The cable itself is covered in foam so it's quite hard to see, feels well joined when I push the ends together.
Is there a way to test that there is a join through to the aerial?
mikeWalsall
Re: Radio Bongo...
Post by mikeWalsall » Fri Nov 16, 2012 5:27 pm
You could test for continuity with a multi meter..
Re: Radio Bongo...
Post by g8dhe » Fri Nov 16, 2012 6:13 pm
It might be worth checking that the radio itself is actually working, push a wire into the aerial socket at the rear about 30" long do you receive any signals ?
If that works OK, then its probably worth checking with a meter for two things;
1. That there is continuity between the end of the plug and the external aerial.
2. There is NO continuity between the end of the plug and earth/chassis of the vehicle.
hooch
Re: Radio Bongo...
Post by hooch » Fri Nov 16, 2012 6:36 pm
Thanks all, I'll get the meter on the job tmrw :)
hooch
Re: Radio Bongo...
Post by hooch » Sat Nov 17, 2012 5:37 pm
Found the fault, the aerial lead was disconnected at the joint shown on the wiring diagram. I'd not traced the lead far enough along before. Thanks for the info.
:D
Re: Radio Bongo...
Post by g8dhe » Sat Nov 17, 2012 10:24 pm
Its been reported a couple of times before so its a reasonable bet that would be the cause ;-)
