snapped timing belt
Ianat64
snapped timing belt
Post by Ianat64 » Tue Jun 11, 2013 8:00 pm
Snapped timing belt. This happened on the A9 just north of Stirling.I've replaced the rocker arms and timing belt. the engine fires but badly. My garage want to know if it is likely to be a case of bent valves, or are they missing something else, before they charge me a fortune to remove the cylinder head etc.
Re: snapped timing belt
Post by Bob » Tue Jun 11, 2013 10:35 pm
Most likely the valves are bent, possible damage to pistons, too, I'm afraid.
This is what's known as an 'Interference' engine, ie belt breaks = damage.
Really sorry to hear this, but I'm not sure I would let this garage work on your Bongo if they don't know this. They are very unlikely to know how to bleed it once its back together.
Very best getting sorted.
Edit: Which engine do you have?
Post by Northern Bongolow » Tue Jun 11, 2013 10:44 pm
check the cam hasnt snapped under the bearings, and the conrods.
if its snapped the rockers it may have lifted the head also, check its straight,
Diplomat
Post by Diplomat » Tue Jun 11, 2013 10:47 pm
It's got to be one of the most brilliant automotive design ideas of all time - fitting timing belts to 'interference' engines.
Am I right in believing that VW have gone back to chains in the T5 series? And I seem to think I heard that the belt in the T4 also drives the water pump!
Frank
They flew, I took up naturism
Coradia63
Post by Coradia63 » Tue Jun 11, 2013 11:53 pm
This is what happened to my brother inlaws Vectra 1.9 CDTi cambelt drives water pump the water pump siezed and bang luckly the rocker arms are weaker than the valves all 16 rocker arms snapped but no other damage internally.
1995 Ford Freda 2.5 TD 4x4 AFT
Post by teenmal » Wed Jun 12, 2013 9:57 am
Hi Ian,its most likely that valve damage has occurred (this engine is not fitted with weakened type valve gear as V/H etc)
The garage need to carry out a Compression test to prove the fault before removing the head.What garage is the vehicle in?.
Good Luck.
martin70
Post by martin70 » Wed Jul 24, 2013 5:06 am
same thing has just happened to mine 95 diesel .What was your outcome?
