My power steering fluid is on the minimum mark. Can I just use generic power steering fluid and is there anything special I should do or do I just remove the reservoir cap and pour it in.
Cheers.
Sara
- mountainmummy
Why, oh why did I chose such a naff forum name????
- mikeWalsall
Re: power steering fluid
It is marked with a full line ... Just use normal Dexron auto gear box fluid to top it up ..
- mountainmummy
Sara, might be a good time to check for a leak and if so it could be beneficial to add some Stop Leak treatments at this point before you top it up with PS fluid.
Good Luck.
Good Luck.
Dexron 3 is the one.
- mikeWalsall
If .. you have a leak you can get combined top up fluid and conditioner (seal softener) in the same bottle ..
fYI, you will need 1 litre to fill the whole system after a full drain.
